85 B2 Won't Start
dkdeford
1985 Bronco II 2.8L carbureted
My baby lost her timing gears two years ago, and it has taken me this long to get them replaced along with a lot of other maintenance under the hood.  Finally got her all put back together, but now can't get her started.  Getting fuel, getting spark.  What else am I not thinking of?
Thanks,
Doug
Jimmy Neutron
Land of Confusion
Alma, Michigan
Timing?
I worked on a BII once where they had no power. It would run great at speeds less than 30mph... the timing was out 180° on the distributor!
dkdeford
dkdeford
Timing?
Can we be certain the timing gears were lined up..., & on the compression stroke..?
Great questions.  I'm confident the timing gears were properly aligned at assembly, and we set the rotor to the #1 post at TDC of the compression stroke. Timing may not be perfect, but it seems like it should at least try to run.  I don't seem to be getting any cylinders firing at all.
Jimmy Neutron
Land of Confusion
Alma, Michigan
Fuel, spark, air, compression, timing... that is all it takes for an engine to fire.
If you have fuel and spark... and we can assume air, there are only a few more things missing out of the equation.
dkdeford
dkdeford
At this point I am circling back around to "spark," because I noticed my timing light seemed erratic.
Tested the TFI module and found the coil isn't getting good voltage.
Now to figure out why not...
