party2849
I own an 84 bronco XLT with a 351W 4 spd manual. I let my friend drive it and he was shifting from 3rd to 4th and missed it and went into 2nd instead. All i heard was teath breaking and then about 500 yards later 1-3 gears would slip clunk while it was in gear. Sounds like a tranny drive gear. If you think that it could be anything else let me know. Differential should be fine, it is smooth while not in any gear. anyway, I am going to have to get a new tranny i beleive. I would like to get a better zf s542 from like an 88-91 bronco. i know that it will bolt up to the motor and the shifter will be in the same spot. However, will the old transfer case bolt right on, and what about the clutch and flywheel, driveshaft and will I need to get any other additional parts besides the tranny? Anything to help me with this, from where to get it and how to put it on. I havent messed around with trannys very much before. Thanks
