Hello everyone Im new to the forum and need a little advice . My bronco will start and run for a couple of seconds and then die like its out of gas . If I feather the gas pedal I can get it to repeat that sequence . It runs for a sec or two and then tries to die . I actually got it to warm up a couple of times by doing that and once it warmed up it ran pretty well although not 100 correctly .
So far Ive changed the fuel filter , coolant sensor, and the external fuel pump . I also cleaned the IAC and put sea foam in the gas tank
I checked the fuel pressure and its 40lbs ,however i noticed that as soon as the engine dies the pressure drops way down . If I spray starter fluid in the intake I runs until I stop spraying so I know its fuel related .
I didnt check codes since the check engine light did not come on before this problem occured
Any help greatly appreciated-
Update edit: TRUCK IS NOW RUNNING!!!!! see my final post in this thread for info
