460 swap
blue460bronco
im swapping a 460 with a 4spd into a 88 ford bronco the bronco had a 6 cyl with a 5 speed. i have a 86 f250 donor truck does any body have any advise or tips on this process? thanks
yo Blue!
WELCOME!
Look at this for some info;
460 EFI Swap in an 89 Source: by Tim C (TnTbronco2, Trail Truck, Street Truck, Crazed, Broke, OoG)
Altho Tim didn't have the 4.9 in there originally...
Too bad there are so Many Useless Comments cluttering up his narrative
300 (4.9) Swap to 460 EFI Info & pics in an 87
Source: by Nathan G (thenag, Bruiser Woods) at http://www.supermotors.net/registry/194/13617
His splices charts may help, but most of it is because he used a speed density EFI 460 out of 97F350; so iggie any MAF stuff.
Too bad he didn't give more info on any othe mods needed.
300 (4.9) to 460 Swap pics in an 85
Source: by K.C. S (The Durrdy Project) at http://www.supermotors.net/registry/5488/19092
not any good info, but maybe a pic there will help with component location or re-location
460 Tear-Down in an 88
Source: by Mosely M at http://www.supermotors.net/clubs/superford/registry/15044/50387
85 w/3 Inch pipe pics in a 460
Source: by ford_munky_man at http://www.supermotors.net/registry/20507/69871
again, pics may help
460 Parts Break-Out Diagram w/Out Nomenclature
by Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/registry/media/72330GL!
L&L Products makes the 460 swap motor mounts that you'll need, and Bronco Graveyard sells them. Or if you want to do the extra work, you can take the percehs out of the F-250 and use the stock motor mounts. Your biggest problem may be with clearance issues of the oil filter and the Bronco engine crossmember. I opted to notch the x-mbr on my 84 Bronco for my 460 swap. You might also find some other useful tips in that topic in this forum under "Dana 60 SAS and 460 swap ", JSM84
ctryboysurvivor
pueblo colorado
broncograveyard has about all you need
motor mount #30907
headers l&l lifetime #30953
remote oil filter #30970
u may need other things but here is something to get u started hope this helps
Staff online
Oldhenry1
