need help with AOD parts
Torsten
Berlin, Germany
Hello,
I brought my AOD transmission to a german transmission-repair shop last year.
this workshop went broke in December 2005 :( /emoticons/[email protected] 2x" width="20" height="20" />
last week I got the fragmented tranny back.
and how should it be, a few parts are missing. :((
I loose complet the inner parts of reverse clutch.
Now I need the original part numbers to oder these parts by an german ford-dialer.
The missing parts are:
* ****** ring
* Bellville return spring
* thick non-selective wave snap-ring
* reverse clutch apply plate
* reverse clutch pressure plate
* reverse clutch selective snap-ring
the car is a 1986 Broco with 302 EFI and AOD-transmission.
thanks for your help.
greetings from Berlin
Torsten
I agree with snowman...Sonnax (http://www.automatictrans.com) is a vg source for parts and less costly than dealership. Try e mailing them (look at "Contact Us" @ page bottom for form that is sent by e mail
But they probably will advise you to contact a retailer such as;
http://www.transmissionpartsusa.com/Valves...ch_more_s/2.htm
Search for Sonnax and look for other retailers w/toll free numbers.
another AOD source is aceomatic.com
here is a Direct Clutch Return Spring that I believe you need w/diagram;
http://www.aceomatic.com/catalog/automatic...asp?t=36&i=3384
other parts are shown here:
http://www.aceomatic.com/catalog/automatics/series.asp?t=36
Toll Free Numbers http://www.acerecon.com/contactus/tollfree.htm
Truck
Sorry about the bad luck, how do you say:
"If you do the work, you'll get money, so you won't go bankrupt" in German?
