3/4 Ton Conversion
brianmelnikow
i have a 79 bronco with a dana 44 front. i also have a 78 f250. ihave put the rear dana 60 from the f250 in my bronco and would like to swap the front. i would also like to keep the coil suspension. i heard that i can swap the steering knuckles out to get the bigger bearings, brakes, and eight lugs. i was wondering if the dana 44 from the bronco and the dana 44hd are the same from the knuckles in. any info would be great. thanks.
Broncoholics
Broncoholics
Washington State
You will not gain much strength by going to the F250 D44 since they are both D44's. The shafts and carrier are the same, only difference is the bearings and brakes that I know of. Look for a front D60 to match the rear.
Billz4x4z
Carnesville,GA
on the other hand if price is an issue,just swap everything over from the danna 44 from the f250 spindle,etc.only thig you wil have to do is modify your brae lines or just swap them from the f250
drubbz
