Interesting TFI/Ignition info
Finally got my friend's 88' ignition sorted out (the guy who "worked" on it before me reversed the leads on the resistor between the coil & dizzy smoking the resistor & causing the no spark problem) but in doing some research I ran across this little tidbit that I hadn't known about.
Seems the dizzy mounted TFI's just quit altogether & **** the spark when the temp reaches 257* (125*C) but as soon as it cools down the engine fires up just fine without leaving *any* trace of what the problem was.
Nothing to be done about it as far as Ford is concerned but worth knowing about.
http://www.autosafety.org/ford-tfi-module-...lass-settlement
73coupe
Wapakoneta,OH
If my camera hadn't crapped out would post pics of a solution
on my 91 CV, I remote mounted the TFI to the fender
used the mount for a PCMI I got from a local yard modified it
to fit the TFI next was making a wiring harnes
I used a junk TFI split it apart gutted it and soldered wires ran
them out and over to the remote mount
extended the facotry harnes and routed to the remote mount
so far 19k miles
Virgil3rd
