what do i need? Changing automatic to manual locking hubs.
blkstang2002
Hello everyone, well i have a 1996 ford bronco and i just bought it a month ago and im having problems with the automatic locking hubs. anyways i wanna change to some manual locking hubs. what will i need? can i just buy a kit and thats it or do i buy the kit and some other parts since it was automatic style? i dunno, im new to this bronco stuff. please help. thanks
heres a pic of my new toy! OJ special!!
muddinlate86
va.beach
i belive all you need to do is go to the parts store and the sell a kit that converts them but you still have to get the new hubs too.get the warn premiums there awsome!
GOOD LUCK
blkstang2002
how much do the warn premiums go for and what are the differences? thanks
BroncoJoe19
This is a good discussion about converting to manual hubs.
The first post links to the purchase price at broncograveyard for warn premiums.
http://broncozone.com/forums/index.php?s=&...ost&p=69356
Scanned images of manual parts
http://broncozone.com/forums/index.php?s=&...ost&p=65094
A good thread advicing to go with the premiums.
http://broncozone.com/forums/index.php?s=&...ost&p=74930
michibronc
Flint, MI
Hey thanks yall. i really appreciate all the help.
You may be able to do it cheaper on ebay (not likely though), but the folks at Jeff's Bronco Graveyard are tops to work with. I give them as much business as I can.
Here's the link for all the parts you'll be installing.
It includes the Warn Premiums and also the spindle nut kit that you need.
You'll need a torque wrench capable of applying 150 ft lbs. You'll also need a spindle nut socket to put the new spindle nuts on. It's a must. You'll also need it in the future to replace / repack your front bearings if necessary.
Here's a link to a thread that I participated in. Meisk5 is the man. He knows all. I'd HIGHLY advise looking through the links that he has posted in that thread. They'll help you a lot. The instructions that come with the hubs make perfect sense now that I've done it, but they didn't at first. I'd also recommend renting a spindle nut socket kit from autozone or somewhere similar to help remove the factory spindle nut that you'll be replacing. Don't buy one because you'll probably never get to use it again.
Also at the end of that thread, I have a pic of some probes that I picked up to help with the swap. They were USA made, only $10 and saved me hours of swearing. They are quite handy to have around.
Good luck, you'll learn lots about your Bronco's front end doing the swap. I did.
On second thought, if you don't want to purchase the spindle nut socket that I linked to above, you can probably get it on loan from autozone as well. The one I linked to is only $15, USA made, and will be pretty handy to have around though if you can swing it.
blkstang2002
cool. thanks. i wanted to also ask, when i called about the warn premium locking hubs, they said id also need a conversion kit. i believe its called a spindle nut conversion kit. is that true? they said id need it cause mine were automatic style.
blkstang2002
also i have a question, i found a 1982 bronco thats being parted out, it has the warn premiums on it. can i take the spindle nut and hubs from it as long as it has a dana 44???
BroncoJoe19
I'm pretty sure that question came up and was answered in the first thread I posted for you, and if I recall correctly, it depended upon whether there were four or five screws holding the faceplate of the hub on.
blkstang2002
cool. yep, yer rite. so yea, i have the 3 ***** type of automatic hubs and looks like i need the conversion kit. so will those 82 model locking hubs work if i get them? it has a d44 also.?
blkstang2002, the Warn hubs on the 82 should be the same as what you get for your 96. Be sure that your conversion kit from the 3-***** 96 hubs matches up to the hubs in the 82, which should be 5-***** like my 84. JSM84
Virgil3rd
