fuse terminal
broncopinoy
Hi there,
I have to replace fuse terminal as the one here attached is really waisted !
where can I get a replacement ? and which other donor car could have a match ?
thanks in advance for your help
I have a bronco 1990 5.0 L Eddie version
Cheers
thomas
Your best bet is from a auto recycler. That fuse block is probably the same from 87 until atleast 94 possibly up till 96. Take your picture with you and look around. F150s, F250's definately use the same one.
broncopinoy
thanks for the advise.....
will shop around
cheers
thomas
snowman74
Oklahoma
I'd have to double check my newest catalog, but I think you can get one from LMC Truck.
Snowman74 :)>-
Isometric
