Spare Tire Carrier
Deep
SouthEast Louisiana
Looking to find spare tire carrier parts for a 1987 Eddie Bauer Bronco; I am in the process of restoring this bronco and I am looking for a few minor parts that appear hard to find. I tried Jeffs Bronco Graveyard and they did not carry what I need. Can someone out there suggest a company and/or vendor that will carry these parts.
Thanks
wtfdissux
Buffalo, NY
assuming you want the one that goes on the tailgate try your local junk yards there is one neer me that deals only with 4x4 trucks he prob has over a dozen of them but if the truck has an inside mount i would not recomend changing it as the support inside the rear quarter is not there and they reak havoc on the tail gate with or without the support peice inside of the gate
D
Deep
SouthEast Louisiana
Thanks for your input....my need is for an external swing away tire carrier....have everything but the plate and nut assy. that captures the tire to the carrier.
wtfdissux
Buffalo, NY
if the truck came with one and the tail gate has not been changed then try Jeff's bronco grave yard or LMC truck for new or try almost any bone yard but if the gate has been changed you will need the reinforcement plate that goes inside the gate if the carrier was not on the truck originally you will also need the reinforcement inside the right rear quarter panel other wise the weight of wheel and tire will basically rip the gate apart know this from experience Esp. when using oversize tires
Wihill
