dual exhaust
If you go out the back, atleast use tips that aim it down or you will probably get a lot of exhaust in the truck. The main reason for going out the side behind the wheels, is to keep it out of the way when going over obsticals off road.
ocalabronco
ocala, Fl
out the sides. out the back, no matter where the tips are pointed, will result in "station wagonning", or fumes coming back into the truck, especially with the rear window down.
tompa00
modesto, CA
i have a question. what about having tips come out the sides in front of the rear tires? how bout that?
26585[/snapback]
Unless you have one of these with the angle adjusted right.
ocalabronco
ocala, Fl
but does the original poster have one? doubtful
and tompa, you can run the pipes out in front of the tires, but it takes some tricky pipe bending to get it around the frame so it doesnt hinder ground clearance
1nfinity
I dualled my '85 to the side, and I rarely if ever get exhaust back in. Ground clearance is maintained, and I am very happy with it. So my recommendation is for to the side behind the tire.
srm148
Chandler, Az.
I have had mine both ways. out the back and out the side. it didnt matter, with the window down, I still got fumes. just part of the air flow I guess. good luck!
Pepper
Hi folks, I'm trying to figure out how to do this but I own two bronco 2's myself.
mbtech2003
cape cod, mass
hi i think cherry bomb makes a cheep kit from their vortex line of mufflers. should be available from most local parts stores. ie autozone. here's an pic of one of their kits
300638.jpg :wacko:
me i'm gonna get a new 50 series flowmaster muffler and have a local exhaust shop bend the pipes for me the way i want them to look and exit.
broncobrian
i put true duel 40 series flowmasters on my 89 bronco. i went straight back w/ them. i love it because not many people have it, but when you put the back window down fumes come in.
brian
85_bronco_302
what sounds best out of a 302 duals, with mufflers to 4'' tips or pure straight pipe to 4'' tips?
86monster
Central Texas
I've had it both ways and you're always going to smell the exhaust. I moved them out from behind the tires b/c i kept ruining my tips with rocks being thown up off the tires. I would strongly suggest going out the back, if you use your bronco.
good luck.
bidibronco
Norfolk Va
I have my exhaust coming just before the back tires and I'm not running any type of muffler. Just strait pipes! I do get fumes in the truck when the back is down but as long as you keep the front two windows down as well, you don't get fumed as bad. The thing I don't like about where my pipes are, I get a whole bunch of cab noise from it.
4x4ever
Edmonton, Alberta, Canada
I've got my duals comming out the sides. I think it looks sportier when they come out the back. It looks good on racing applications, like with a roll pan. But it all comes down to personal preference, and if you wanna choke the guy next to you or behind you with your exhaust.
85_bronco_302
ya i think i'm going to go ahead and do mine out the back i think it would look awesome, i might just go with straight pipe down the road in the future tough for a nice powerful sound
Oldhenry1
