upper radiator hose
diymirage
hey guys
i want to order a new radiator hose for the bronco (87-351) because whoever owned it before me, put on an accordion hose, and it is junk
the hose i need is a simple Z shaped hose, from the radiator out 10 inches or so to get passed the fan, over towards the drivers side and another 90 to hit the water neck
the number autozone gives me is 71283 which looks like an omega sign and does not get passed the radiator out far enough to clear the fan
anyone have any idea what the right number hose is?
(ill toss up a picture later)
What engine?
Please fill in your profile.
For 5.0 see images at https://www.rockauto.com/en/catalog/ford,1987,bronco,5.0l+302cid+v8,1105883,cooling+system,radiator+upper+hose,2058
For 5.8 https://www.rockauto.com/en/catalog/ford,1987,bronco,5.8l+351cid+v8,1105894,cooling+system,radiator+upper+hose,2058
Help
Order Status& Returns
Cart(1)
Menu
Part Catalog
FORD
1987
BRONCO
5.8L 351cid V8
Cooling System
Radiator Upper Hose
Parts
Molded Rubber
Tap to expand
GATES 21512 Info
Molded Coolant Hose
{Click Info Button for Alternate/OEM Part Numbers}
Choose:
[Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] ($5.49)
$5.49
Tap to expand
DAYCO 71283 Info
Curved; Type Dual / Small ID 1.50" / Large ID 1.75" / Span 19.50"
Choose:
[Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] (Only 4 Remaining) ($6.12)
$6.12
Tap to expand
O'REILLY/MASTER PRO 21512 Info
Upper Radiator Or Coolant Hose; MOLDED COOLANT HOSE
[Wholesaler Closeout -- 30 Day Warranty] (Only 15 Remaining)
$7.64
Tap to expand
CONTINENTAL 61368 Info
Primary # 1
Molded; I.D. 1.500"; Length 30"
Choose:
[Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] (Only 1 Remaining) ($7.66)
$7.66
Tap to expand
ACDELCO 26125X Info
Professional; Molded; 1-1/2" x 1-3/4" x 30 3/32"
{#88908823}
(Only 2 Remaining)
$16.64
Flexible
Tap to expand
GATES 25535 Info
Flexible (Standard)
{#FF305}
$12.04
Tap to expand
ACDELCO 31649 Info
Professional; Flexible; 1-1/2" x 1-3/4" x 27"
{#88909270}
(Only 1 Remaining)
$14.63
Related Parts
help.pngChoose for Me to Minimize Cost
envelope.png Send these listings to a friend
diymirage
diymirage
thank Mieks,
the engine is a 351
best i can tell, it came out of a 85, but the chassis is an 87
the hoses that show in your post look like the one in bought ( and the number on the dayco is the same)
no way that fits
i like the looks of the gates 21631
it shows for a 5.0 but my truck is so cobbled together who know what it should be
come to think of it, it looks like my waterneck comes out horizontal...if the silly thing would be vertical the hose i have would fit
does this sound like i just have the wrong waterneck ?
diymirage
diymirage
on a hunch i stopped by autozone last night and picked up a new water neck ($ 7.95) and sure enough...it is different
im hoping that once i swap that out, the hose will line up as it should
diymirage
diymirage
Good job!
Not quite, the Water neck is leaking
Not pouring, about a drip every 2 seconds at idle
I guess I'll tear it apart tomorrow and only use rtv instead of a papergasket with a thin coat of rtv like I did this time
I just had that issue with a paper gasket I try'd to install recently. It act'd like it melted. Got mine form O'reilly. Blue RTV and no more issues.
diymirage
diymirage
thanks SKitter,
i went throught all the steps to get it right
blocked the neck and the intake side to make sure nothing was warped
mocked it up without washers to make sure the bolts werent bottoming out
lines up the gasket with the intake, then filpped it over and lined it up with the waterneck to find out the bypass hose ****** was off by a bit, enough to leave hardly any meat for the gasket to seal on
switched it our for a carquest version and everything seemed good for a few days
went for a little ride yesterday, and found more water on top of the timing cover
i will double check everything is tight, but it if is, im putting on a water neck with O rings
One issue I had the the thermostat trying to fall out of the groove when I attached the water neck back on. I used a small dot of RTV to hold the T-stat in place and had no issues.
diymirage
diymirage
Yup, did that too
Still leaking, so I bought an o ring water neck
Should be here by Friday
Ya know, I didn't have a coolant leak till I join'd in on this conversation. ? Thankfully mine is just a bad 5/8 hose going from the intake to the water pump. Stop by O'reilly tomorrow and get a new one.
diymirage
diymirage
So what your saying is...i started a trend?
I think that 5/8 hose actually has 2 different I D s, so keep an eye on it
99Yo Skitter,
The bypass hose is available by Dayco;
 RADIATOR Bypass HOSE
PART NUMBER: 70646
Back to results
ATTRIBUTES
SPECIFICATIONS
Type
Dual I.D. Hose
Small ID (Frac) A
5/8
Small ID (Dec) A
0.63
Large ID (Frac) B
3/4
Large ID (Dec) B
0.75
Hose Length
5 1/2
Branch
More DAYCO parts @ http://www.daycoproducts.com
Got the bypass hose installed, all better now!
bfisher1970
