95' New to Me
zballar
Portland, TX
Im new to the forum so here is a introduction. This seems like the right place to seek answers and share knowledge. I bought my first Bronco on 9/21/17! Really enjoying it so far. It has a 175k on the truck but the engine was recently bored 30 over mild cam. It has a ton of other new parts recently. The interior is custom distressed leather. It has a 3" body lift, and a 6" suspension lift. On some 37x12.5 17 wranglers. It's been many years since I've been able to work on my own vehicle, im excited to get back at it.
Welcome to the Zone!
Those seats look amazing! What carb do you have running the engine?
p.s.  Concider adding your signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc.
You can do that by:
Click your name in right black panel in upper right;
In pop up,
Click, My Profile
Click, Edit My Profile in right side black panel
In left panel, Click, Edit Signature
Enter info
Click, Save Changes
zballar
zballar
Portland, TX
Thanks, Skitter302. It's fuel injected. I'll edit my signature, that's a good idea.
Yo z,
If you have a 95, was cruise control, if equipped recall work completed by dealership? Call dealer & have VIN ready.
This also applies to 94 through 96.
93 Broncos have a different recall ; The affected vehicles were previously repaired using a wiring harness that is not compatible with the vehicle circuit polarity. As a result, the fuse is located in the output circuit rather than in the intended input power feed circuit, and may not offer the intended protection in the event of an electrical short to ground. This could result in an underhood fire. Dealers will install a new wiring harness, or replace the mating electrical component. east302 provided following for his 93 "I found the recall information on alldata...didn't know it was even there so that's a plus. Mine has the updated harness with two fuses instead of one, so it looks like the recall was addressed correctly."
Your Bronco looks great!
zballar
zballar
Portland, TX
Doesn't look after market to me. Would assume it was tuned when the engine work was completed but not sure. I'll have to contact the seller to get some more detail.
zballar
zballar
Portland, TX
Skitter302,
Looks like the ECU/COM wasn't tuned or changed out after all, since the engine work. Any suggestions?
If it drives good don't worrie about it. If it gets bad MPG you'll know it because the ecu isn't tuned for the cam. Rev it up and have fun!
