FOR SALE: Clean/usable Early Bronco parts
--- See something you need., PM me & I'll send you pic's & price. ---
Low time 1983 Ford I-6cyl. 200 eng., bellhousing, Transmission, with T-case adaptor.
8cyl. bellhousing, manual 3 sp. trans., T-case adaptor, J-shift T-case., crossmember
   & mounting hardware.
8cyl. manual 3 sp. trans., with T-case adaptor.
Ford 9" drop-in differential. Needs ring/pinion gear choices, etc.
V/8 Radiator.., very little usage.
Heater box W/heater core installed
Hood latch assemblies (2)
Good rear main tank.
Manual steering boxes (2)
Manual steering shafts (2)
Emergency brake pedal assy.
Rear axles (2) one with bearing.
Stock front coils
Many front drum brake parts--spindles, hubs, etc.
Aux tank hardware.
Pitman arms (3)
clutch fulcrum hardware.
Gas pedal assy.
Clutch release arm.
V/8 starter.
Seat side mechanism covers.
"C" bushings.
Motorcraft 2brl. 2100 carb. for 3 sp. trans., automatic choke.
V/8 radiator hold downs.
CARTER AFB 4brl carb. 3200-9605S
---- Plus other misc. parts I may pull out of drawers/cabinets in time. ----
---- Use "PM" if interested.., Pricing will be very fair.
SAMPLE PICS BELOW
fred tyler
