Yo Fred and OG,
As requested;
Wiring Diagrams in an 88;
![bronco-1989-fuel-system--pg-92.gif bronco-1989-fuel-system--pg-92.gif](https://www.broncozone.com/data/attachments/21/21848-d19689fc7509083638b9635f6639bc4f.jpg)
by SeattleFSB
Inertia Switch Location in an 88 & pic; "..firewall forward of the e-brake & clutch pedals..."
Overview; "...The inertia fuel shutoff switch is a safety device which interrupts fuel pump power in the event of a collision. If the inertia fuel shutoff switch is ‘‘tripped’’ it must be reset by depressing the button on top of the switch..." location described is for other years
Source: by Ford motorcraftservice
Fuel Pump Relay Socket Corrosion Info; "...if you had corrosion in your relay socket, then you probably have it other places. one at a time unplug all relays and connectors on that fender and spray them down with contact cleaner. then after you let that do it's job for about 30min-1hr, go back and unplug each relay and connector again (one at a time) this time put them together with di-electric grease. you can buy a tube of it from any electrical/electronics supply or auto store. make sure you get everything plugged back in..."
Source: by datrimm (HiTechRedNeck)
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/?pid=74587&mode=threaded
Some basics;
The engine temperature must be greater than 50° F for the Key On Engine Off (KOEO) Self-Test; and greater than 180° F for the Key On Engine Running (KOER) Self-Test if you cwn get it running.
Make sure A/C switch is off and transmission is in Park (automatic); or in Neutral for a Manual & release clutch.
Then turn off all accessories/lights (close driver's door) , etc.
Do KOEO test for now
Post Code(s) here
