NEED HELP I CUT THIS AND TRANS IS EVERWERE
sgtbeastmode
I have 1989 bronco, I thought my cats were clogged so I just cut them out,right at the y shape in the pipe after the o2 sensor. I did this to my buddy's 91 but I now have trans leaked everwhere.. there is a hose I see to what I thought was the first cat. Any idea what it's called or for... if you can text me 4079298863 I need to know what it is, to get it replaced... asap
yo SGT,
WELCOME!
96 Bronco-F-Series Workshop Manual (PARTIAL)
Same as most earlier years exc. for OBD II in 96, 4WABS (93-96); ABS (87-92); Air Bag (94-96); 3 ***** Automatic Locking Hubs (Built from May 95 through 96); Spark Plug Wire Routing & Firing Order (The firing order for 1987-1993 5.0Ls is 1-5-4-2-6-3-7-8. The firing order for 1994- 96 5.0Ls & all 5.8Ls is 1-3-7-2-6-5-4-8.);
2-piece Spindle Rolling Diaphragm Seal (RDS) used on 5/95 to 96 Broncos & F Series 1/2-ton 4WD
and a few other items that I still need to research
http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
Section 07-01A: Transmission, Automatic, E4OD
IN-VEHICLE SERVICE
Fluid Cooler Lines
Transmission Fluid Cooler Tubes, F-250, F-350, F-Super Duty, Bronco, 5.0L, 5.8L, 7.5L
As RON advised;
See if you can use this diagram to indicate leak area;
Around #`2 - 13 my 96 came with rubber hose section so that trans fluid could be flushed using Old Rotunda or current BG Trans fluid fluseher/refiller unit.Item Part Number Description
1 7A095 Transmission Fluid Cooler
2 8005 Radiator
3 7A031 Fluid Cooler Tube
4 7D273 Fluid Tube Connector
5 372223-S101 C-Clip
6 7N291 Transmission Fluid Cooler Line Clip
7 7A030 Fluid Cooler Inlet Tube
8 — Connector (Part of 7000)
9 7000 Automatic Transmission
10 376240-S Clamp
11 N809635-S165A Hose
12 7F113 Inlet Tube
13 7F112 Outlet Tube
A — Tighten to 23.3-31.7 Nm
(17-23.4 Lb-Ft)
B — Tighten to 3.1-4.3 Nm
(27.4-38 Lb-In)
C — Tighten to 10-14 Nm
(7.4-10.3 Lb-Ft)
seansz28
