Removing the interior paneling
BigSpenc
I've decided to put Herculiner on the interior of my 94' Bronco. I have pulled all the seats out as well as the carpet and am trying to pull the interior paneling off so that I can remove the carpet over the wheel wells. I have removed all the screws that I could find but while the panel is loose I still can't manage to get the panel off. Does anyone have a diagram of all the connectors for this panel or if anyone could help it would be greatly appreciated.
I believe there are a few blind clips holding it. If you can get your hand behind it, you may be able to get close to where they are.
yo BIGSPENC,
When removing panels retained by pushpins, use Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent to carefully pry trim panel from inner panel. Replace any bent, damaged or missing pushpins.
I use better-half's old meat fork.
Refer to the following illustrations for removal and installation of trim panels.
Parts Break-Out Diagram in 92-96
Trim Panel, Body Side, Lo-Series, Bronco
Item Part Number Description
1 — Panel Assembly, Body Side Inner (Part of 27864)
2 31012 Quarter Trim Panel
3 381801-S58 *****
4 385402-S58X *****
5 381801-S58X *****
6 601B32 Cover, Rear Seat Shoulder Strap Retractor
Quarter Trim Panel, Custom XL, Bronco
1 31608 Armrest Support
2 31604 Armrest Base
3 24100 Front Arm Rest Pad
4 62866 Ash Receptacle Assembly
5 24146 Armrest Clip
6 31012 Quarter Trim Panel
7 N803414-S58 ***** (2 Req'd Each Side of Body)
8 N610963-S58 ***** and Washer Assembly (2 Req'd Each Side of Body)
9 380934-S36 ****** Drill Point (4 Req'd Each Side of Body)
10 N803103-S58 U-Nut (2 Req'd Each Side of Body)
Quarter Trim Panel, Hi-Series, Bronco
1 27840 Body/Side Trim
2 390934-S36 ****** Drill Point
3 — Bracket (Part of 27840)
4 31012 Quarter Trim Panel
5 N800943-S303 ****** Round Washer Head
6 381801-S58 ***** and Washer, Oval Head
7 N800942-S58 ***** and Washer, Oval Head
8 601B30 Rear Seat Shoulder Strap Opening Bezel
Body Side and Roof Rear Garnish Mouldings, Bronco
1 517C04 Roof Trim Rear Moulding
2 29004 Quarter Window Garnish Lower Front Moulding
3 N8071545-SW Pushpin (6 Req'd Each Side)
4 N807372-S Pushpin, Nylon (2 Req'd Each Side)
5 29010 Quarter Rear Window Garnish Rear Moulding
6 29126 Body Side Window Garnish Moulding Front Bracket
7 N800486-S9 Bolt and Washer
8 N801157-S58 ***** and Washer (2 Req'd Each Side, 1 Req'd Center)
9 518B34 Roof Trim Rear Moulding Joint Cover
10 29070 Body Side Window Garnish Moulding Bracket
pushpins in orig interior colors are still avail from Ford dealers; some will order them for you, others don't bother
Trim Color Code, Interior Location in Door Jamb Label (Data Plate, also referred to as the Patent Plate & the Warranty Plate) pic in a 95 The letters and/or numeral under BODY designate the interior trim, seat and body type.
Ford part number N808658-SSD (Mocha Tan) in a 95
Source: by Jon F ("The Bronco")
These come in black, and some use Vinyl or plastic paint or dye to color them
Trim Panel Retainer, Interior, Plastic in 92-96 (Xmas Tree, Dorman part #700-771 pic
Source: by Dorman http://www.dormanproducts.com/catalog/hardware2006/397-402_Sec20_Part4.pdf
Trim Panel Retainer, Interior, Plastic in 92-96 (Xmas Tree, part # N19374) (New URL as of JUN 2010) Bottom Head Diameter: 19/32" - Stem Diameter: 9/32" - Stem Length: 27/32"
Source: by northland fasteners http://shop.northlandfasteners.com/N19374-Trim-Panel-Retainer-N19374.htm;jsessionid=7B7DAA040FC24851FB3C92DE5104546F.qscstrfrnt03
more interior trim LINKs in my site @ http://www.broncolinks.com/index.php?index=322
digs
