no acceleration
89xlt
i dont have alot of acceleration and my shift points seem bad.. when i let off the gas it sometimes has a clunk and when i get back on it it will have another clunk any help
89xlt
i have a aod trans and auto hubs push button 4x4
You need to share a little more information. What gearing do you have? What size wheels? Have you changed anything in your drive train? Have you checked your Tranny fluid?
Add a little more information about your truck in your signature, it will help.
Good Luck,
89xlt
stock everything just added new tires which are 31s
Krafty
Ontario Canada
the clunks sound like bad ujoints in the drive shaft, and the sluggishness could be sign you need a tune up, whats your engine and gear ratio?
89xlt
302 and i think 3.53 whatever came in the truck just had a tune up and had some u joints replaced coming out the transfer case
yo 89,
Did you try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
Look Codes up in my broncolinks.com site using the new Search function.
KOEO
KOER
Clunk, Driveshaft; a Bronco driveshaft normally is two pieces that slide together. The slipshaft is normally covered by a rubber boot in the middle like in the pic below;
The Bronco rear driveshaft is of the double Cardan type which incorporates two universal joints, a driveshaft centering socket yoke, and a driveshaft center yoke at the transfer case end of each shaft. A single universal joint is used at the axle end of the driveshaft.
miesk5 note, slip yoke is often referred to as the Slip Shaft Spline; see part 4421 in above diagram @ center
mark it before taking it apart, in order to align splines; separate it at the slip yoke; grease the splines, reassemble, using new clamps on the rubber boot
Slip Shaft Spline Lubrication pic; "...If your Bronco suffers from the notorious thunk this is a good time to **** your shaft.." by TRUCKY18 (Bco)
When you check the u-joints, park it on a flat spot, block the wheels & put it in neutral. That way the driveshaft will be free to move if the u-joints are bad...";
Lana Kane
