93' 5.0 Automatic...This problem started 2 weeks ago...Would not start but the fuel pump keeps running. Try several times and sometimes pump would run a couple of seconds, like it should, cut off and the engine would start...This has gone on for 2 weeks...no codes and cannot pull codes when the ignition is on the fuel pump continues to run. Started once in this condition but ran rough and the check engine light was on...still no codes...have 40 psi at the fuel rail...yesterday, started it in the morning turn it around in the drive to replace the fuel sending unit...when I finished that project the Bronco never started again...and the fuel pump runs all the time...code reader won't pull codes...Tried the start by jumping the starter solonoid no key in ignition...didn't start...think she died
Thanks for any help
Thanks for any help
