8 Point Roll Bar Install
Mudmagnet63
Geary Oklahoma ( go sooners )
I started on the roll bar today. It's an 8 point that I weld together myself.It seems I may have forgot how much goes into welding and finish fitting tubing. The bars were cut to fit on every joint except for a few.I kept cutting and grinding until I had a good fit ( well most of them were a good fit) The bar is supposed to make the glove box unaccessable, but I changed the way the front sets by angling the front bars by about 5 degrees to keep my fuse box accessable. I should be done welding tomorrow and then to paint and wrap with foam and tape. I'll post some pics when I'm done.
Mud
M
Mudmagnet63
Here are a couple of shots of the 8 point bar installed. The soft top is from a Jeep JK that I had last year we modified it to fit the bronco. It.s just a little short so I'll order a new one this fall. Now time to start sanding the hard top.
S_bolt19
Colorado
Looks good, where did you get the cage from? Did you get your glove box taken care of too?
M
Mudmagnet63
The bar came from toms bronco parts it was pre cut and I had to weld it but I saved about $500 by doing so. The glove box issue was resolved by angling the front bars all the way to the outside of the interior.
Chapin1736
