Yukon axles
nightmare76
I decided to upgrade my rear axles to 31 spline when I bought an ARB. I noticed, however, that the axle seal and bearing retainer were quite different than
the originals. It appears that the seal is supposed to be sandwiched between the bearing and retainer on the axle shaft. Has anyone else run into this issue?
bartowb
Cheyenne Wyoming
not sure how you got your axels. when i got mine everything was already pressed on. also in talking with toms there is no longer an axel seal required. it is all built into the axel.
79' Buckin Bronco
