texan79&96
- Joined
- Nov 29, 2004
- Messages
- 172
- Reaction score
- 0
i finished welding in the inner pieces of my wristed arm tonight. what size bolt holes should i drill. i have a small delta drill press i hope will do it. also does anyone reinforce the other arm like the first step of the wristed? i have a 79 and its gonna be spinnin 35s will the other arm hold up? why is it that everyone always does the passenger side does it matter which side you install it on? out of curiosity what settings and rods did anyone use to do this. i used an antique lincoln 225 with a craftsman torch from 1969 haha...and about 4 grinding discs so far on a dewalt 41/2" grinder. i used just some lincoln 6011s at 145 amps. i also sandblasted the arm first. i gave $25 for about 13ft of 41/2" x 1/2" plate it was in their scrap pile and wrote it off as farm use! with it being that wide my arm goes up into the c shape contours. it seems like if an arm was to bend it would bend at the skinny part at the back where it mounts is this correct??
