wont lock in
mrbones
i got a 1992 push button 4x4 and it wont lock in i changed fuse and cheked the connection and it still wont lock in any body got any idea what it could be would be greatly appreciated
Welcome to Bronco Zone!!! Try searching the forums, there's some links to help you troubleshoot your 4WD system in the tech articles and support forums. Most often, the shift motor or relay for it will be bad. Does the "4x4" light up on the dash when you push the switch?
M
mrbones
neather one of the lights push 4high nouthing 4low nouthing its driveing me nuts
seawalkersee
Outside KCMO
Get a buddy, have him hop in and push the button. You get your @$$ on the ground and tap (I stress tap) it with a small hammer. Ifn it goes in you need you a motor. If not check the relay.
If You pound the **** out of that motor and it was good you will ruin it and need it too without fixin your troubles.
Chris
scrubtopdoc
