Wiring diagram tank to guage 1991 Ford Bronco
Yo Jim,
Inspect Pump/Gauge Connector for corrosion, loose wires, etc,
Tech Tip Guide, General; "...Many times, the Ford fuel pump hanger/sender assemblies are frequently found with extensive corrosion. Over time, the terminals can loosen and cause intermittent loss of continuity. Erratic reading of the fuel sender level is one of the other problems that could occur..." : by spectrapremium.com
Inspect Ground G100 @ LH front of engine compartment on upper radiator support,in front of WS washer/Coolant overflow tank
Connector Elimination by Soldering in a 91 @ https://www.fullsizebronco.com/threads/eliminating-the-fuel-pump-connector-87-95-trucks.114389/
Here are the 1990 F Series/Bronco Pre-Delivery Shop & Electrical & Vacuum Troubleshooting Manuals (EVTM), Partial by member Kingfish999 in Google Drive (similar to your 91) @ 1990 Ford Truck service manuals - Google Drive
Slow scrolling for my slow Comcast Highest Cost Blast Internet..
Suggest you download the docs for faster scrolling and to use the page index.
1991 Bronco Dealer Brochure by Ford via via Dezo's Garage @
https://www.xr793.com/wp-content/uploads/2020/07/1991-Ford-Bronco.pdf
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf via member BroncMom
Quick gauge test,
Unplug the sensor wire at the tank. I think it should read full.
Ground the sensor wire at the tank and I think it should go to empty.
If the gauge does that, then the problem is in the tank, either a sending unit or bad tank ground.
J
jimbronco91
Great Falls, Montana
Yo Jim,
Thank you I truly appreciate the help.
J
jimbronco91
Quick gauge test,
Thank you so much
79' Buckin Bronco
