Windshield wiper retro fit
BobBeck
I am in the process of retrofitting my 1967 Bronco with electric widnshield wipers from a later model bronco.
I am having some trouble with the wiring, I have 4 wires colored blue/white/red and black coming from the motor, I have also purchased a intermittant wiper switch to install. My problem is where do all the wires connect.
The switch itself has a ground wire directly mounted to the switch.
The intermittant wiper switch has 6 wires, they are color codes red, white, black with purple stripe, black with green stripe, black with white stripe, and blue with Orange stripe.
As you can imagine I am starting with vacumm wipers so this is completely new with nothing in the wiring harness.
Any help would be greatly appreciated.
50joe
Trenton NJ
What year Bronco did you snag them from? Some of the intermittant wiper systems have the delay controller mounted right to the wiper motor, some have a seperate delay box. I can try to pull some diagrams, but need to know what system you are using.
BobBeck
My system has the delay box separate from the motor.
50joe
Trenton NJ
Got ya there, but Ford loved to play with the colors of the wires from year to year, so if you know aprox what year its from, I can try to help ya out. I'm guessin you have to make your own harness?
BobBeck
The wiper motor came out of a 72, but I am not sure what year the switch and delay came out of.
