Windshield Washer Pump
MOJIGGA
My windshield washer pump doesn't seem to want to work.
the wipers activate, but no fluid is spraying.
I replaced the pump already, so I was just wondering if anyone knows of a relay somewhere that could be bad?
there is a clicking noise under the dash when I go to activate the washer, so I'm thinking that may be the issue.
I just added "1996 Bronco Eddie Bauer 5.8" to your profile.
Unfortunately it took me 35 minutes to find one of your posts where we yakked about it, because this site is slow. Is this correct?
Pin-Point Testing & Wiring Diagrams in a 96 from 1996 F-150, F-250, F-350, F-Super Duty and Bronco Workshop Manual
http://www.diesel-dave.com/vehic/manual/stj/stjs1g0l.htm
Circuit in Multi-Function Switch (MFS) Testing & Wiring Diagram in 92-96; "...the MFS testing is done with connectors disconnected; it's strictly an internal test of the MFS; There is no testing for the WCM - you test the MFS, the wiper & spray motors, and the wiring. If they're good but don't operate, it has to be the WCM by elimination..." Miesk5 NOTE; Brake Light & Turn, High & Low Headlight Dimmer, Flash-to-Pass & Hazard CKTs are a Feed-Through Circuit in Multi-Function Switch (MFS). by Steve at http://www.supermotors.net/registry/media/225114_1
See more tests and info at http://broncozone.com/topic/25303-windshield-wiper-and-spray-not-working/
Elmomo
