wierd idle
92bronco_in_progress
Yeah its a 92 bronco
Waretown, New Jersey
this is something thats been bugging me, but it only does it in park, and once it comes down to normal idle, the problem is a little surge, like from 600-800 RPMS and then back, it doesn't do it in drive at all, plugs and wires are brand new, i don't have a vacumn leak, i checked the TPS, i don't know, its not a big deal but it annoys me sometimes
thanks in advance
Shadow_D
Schenectady, NY
Hey Joe... is there a page that explains the cleaning proses??? I looked at that page and it just explains how it pooerates...
BroncoJoe19
New Jersey
Hey Shadow.... pooerates... ? I see you got dyslexic fingers today! :) /emoticons/smile@2x.png 2x" width="20" height="20" /> ... ? LOL I get them all the time.
Gee... I thought that it did talk about cleaning it. Well at any rate, just pull it off and spray the moving mechanism with carb cleaner, and let it dry. I guess if you want to get fussy, you can dissassemble it and clean the moving part with carb cleaner, and the electrical part with electronic contact cleaner.
From... http://www.fordfuelinjection.com/index.php?p=39
" The plunger and internal spring can get clogged with dirt and oil. This will slow down the air flow and not allow the IAB to function properly. Remove the IAB and clean it. There are 2 halves to the IAB, and you can not buy just one half, but you can take it apart to clean it. But if the internal solenoid is faulty the IAB needs to be replaced."
Shadow_D
Schenectady, NY
Hey Joe yea I guess the fingers didn't want to work right :lol:
I guess I was looking for the complete disassembly to clean it.
Thanks
Shadow_D
Schenectady, NY
Well I feel like a fool now <_<
I took mine off and saw how it comes apart...
I went and cleaned it up, put it back together and put it back on the truck... Good news is my idle has stopped looping :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
Bad news is I now have a CEL :( /emoticons/sad@2x.png 2x" width="20" height="20" /> I'm not sure that is related to the IAC cleaning because the EGR got knocked around when I was trying to remove that spring bracket. The EGR is lose now so I kinda think that is the CEL as I haven't checked the codes yet...
Croneybones
Meadville, PA
On this topic, mine does roughly the same thing. When I first start, it idles around 2000 rpm for a bit, but if I tap the gas, it will idle down. Once in a while, it will do the weird idle described above. The other day, it stalled and wouldn't start back up for a while. Would the IAC cause all that?
BroncoJoe19
New Jersey
Yeah, if it is sticking. One shouldn't have to "tap the gas" like they do with a carbed engine. EFIs don't have a stepped high idle cam like a choke does.
Bigtrucks44
Louisville Ky.
this is a very agrevating problem i have an 89 that does the same thing and it bugs me but it an't hurting anything so oh well
BroncoJoe19
New Jersey
If it bugs you, IMO you should take care of it. Once you do, you'll find that one realizes a certain amount of satisfaction that comes with being able to complete a task that makes the truck run better, and costs next to nothing to do.
The IAC is held on by two little bolts. Real simple to remove and clean.
Yo gang!
I just did same; had the IAC DTC; IAC was ok, cleaned it and then saw the 2 holes in da Throttle Body were very fouled; claned em out... cause was prob the cheap (read, VERY CHEAP.. and ya get what you pay for) WAWA gas I used for about one year.
One more Link; Cleaning in a 93 5.8 Source: by Bobby
scroll to 3rd row (5/16 bolts hold IAC to TB)
one more Link,,, lol;
Hitachi Idle Air Control Valve Recommended Cleaning Procedure
Source: by Steve83
one more Link.... (my pc is back up!)
Long Crank Times may be traced to a sticking Idle Air Control (IAC) valve, TSB 97-9-5 for 95-96; "...After a 1-4 hour engine soak time, long crank times and/or long crank to start followed by a stall may occur on some vehicles. No further stalling or rough idle will occur after the engine is running. The long crank and/or stall may be due to the Idle Air Control (IAC) Valve sticking. Replace the AC Valve with a revised AC Valve if no Diagnostic Trouble Codes (DTCs) are present."
Source: by Ford via stangnet.com
denny.dikes
