Why doesn't my tailgate handle lie flat?
Broncosaurus!
Oshkosh WI
It used to stay flipped up or fold flat when I bought it, but shortly after I bought it the handle has been stuck like this. I've taken the panel off the inside, looked around, lubed what I could see, and could not figure out why it doesnt lie flat. It is really getting to be a pain. Even when I shut the tailgate it stays out like that.
Broncobeginner123
oceanside, CA
mine was dooing the same, the rods inside are probably bent or warn. i wouldnt doubt in some time you wont be able to use the handle to open your tailgate. I hope it doesnt come to that, but mine did.. Best of luck.
opydawg
SC
I had the same problem with my 92. The handle stuck up and sometimes would not release. Ended up replacing the release mechanism inside the tailgate. Mine had a rusted out spring. You may be able to adjust the mechanism: loosen the bolts and try pushing it down. The 92 has a small amount of adjustment in the bolt holes (they are not just a hole, but oblong). Also, check the plastic clips that hold the rods, they might be shot. I rode around for a while with tailgate panel out so I could grab the side rods and pull together to open the tailgate. Talk about a pain...
Broncosaurus!
Broncosaurus!
Oshkosh WI
I know I am about ready to scrap the tailgate altogether. I hate the window in it and I hate the handle on the inside. I want a regular truck tailgate and a lockable window hinged at the top like a p/u with a topper. Anyone done that?
raceear
Bayonne, New Jersey
I had same problem when I bought my truck couldn't even open the tailgate took the center lock piece out cleaned the rust off lubed it up and also had to bend the arm that is moved by the piece that the rod connects to from the handle that got bent from being pulled on when it was rusted up.Hard to describe but once you get it out you'll seel
