whining and pulling in front end 92
pwcdoctor
I have a 92 Bronco and Im getting a whining noise and pulling in the front end, I have new bearings, new tie rods/center link, im getting a whine noise and it pulls sometimes, cant figure it out.
P
pwcdoctor
Is the brake caliper hanging up ? Does it smell like hot brakes when it does it ?  :D /emoticons/[email protected] 2x" width="20" height="20" />
28135[/snapback]
I believe the right one is hanging up, but it pulls to the left and sometimes to the right, can it do this? It also sounds like the whining is coming from the left.
ocalabronco
ocala, Fl
check the tightness of your wheel bearings, and also feel the wheels to see if they're hot. if they are, your calipers are hanging up. loaded calipers are cheap after the core return
P
pwcdoctor
Sounds like improperly installed wheel bearings :mellow:
28144[/snapback]
Ok i changed the caliper that was hanging up and noticed it wobbles a little from top to bottom, maybe my spindle nuts are a little loose? Also what could you do wrong when installing new bearings, it seems pretty much only one way.
scrubtopdoc
