Where to buy new driveshaft???
AdamDude04
Well I have no idea where my head has been.. I have low speed shutter, clunking that's getting worse, and now constant metalic something or another that will vary with speed. I must have been thinking I replaced all the ujoints..when in reality I just replaced the rear due to the double cardan driveshaft. UGH.
Anyway, need one ASAP. Where can I get one for an 89/302 with an AOD?? I found this at checkers auto ($203) but can only have it shipped to my home. Napa is no good, and advanced only has one for a C6 (also needs to be shipped, same price minus $50 e-coupon)
Cardone - Drive Shaft Part Number: 65-9416
Line: A1
Remanufactured
Remanufactured
Rear
With 3 Speed Automatic Transmission
4 Speed Automatic Transmission Aot Transmission
I don't know if this is compatable with the AOD?
Any ideas?? The shops I called to just replace the u-joints wont even touch the dang thing because I guess they don't have the tools?? And I for sure don't have the know-how on how to replace em myself..been there, tried that.
Bronco-graveyard has em..for $230 plus shipping. But I'm really trying to go local
yo Adam!
Have you tried a local yard yet?
If you need a yard search on-line I use;
ADP Hollander - My Part Shop® used parts finder - their site was messed-up last night, but is A-OK right now
I don't know your location so; I used CT as an example;
Select All Parts.. go thru da drill
then select AT AOD
got a few hit;
88
BRONCO Drive Shaft, Front
24.25WW 0 883125
34532 0.0 $65.00 11 Call BISHOPS USED AUTO PARTS
860-346-2336
800-634-8733
88
0 H06265
50082 0.0 $125.00 14 Call TOM'S USED AUTO PARTS
860-582-7056
or
http://www.car-part.com
and since I just recalled you are from Denver area where my uncle Jack was from (way Noth tho; he was a WWII Marine Fighter pilot!)
88
0 1343
47108 0.0 $85.00 74 Call A A AUTO PARTS, INC.
303-455-4141
800-784-1459
Dave or Diane
303-455-4141
800-784-1459
2180 W. 60th Ave.
Denver CO 80221
89
105-4X4 5.0 C-A 0 1207
53935 0.0 $85.00 74 Call A A AUTO PARTS, INC.
303-455-4141
800-784-1459
89
0 A59384
18184 0.0 $85.00 81 Call Canyon Truck
719-275-5236
another YO
In case ya need the rear;
Drive Shaft, Rear
AT, 8-302 (5.0L) AOD (35-13/16")
89
BRONCO Drive Shaft, Rear
302 ATOD 4x4 0 090040
88457 0.0 $75.00 90 Call Penrose Auto Salvage
719-372-6007
800-610-8074
Terry
719-372-6007
800-610-8074
1650 State Highway 120
Penrose CO 81240
[email protected]
www.penroseautosalvage.com
88
95 88J145
90922 0.0 Call 105 Call ARAGON IRON & METAL
970-484-2577
800-424-2577
ARAGON IRON & METAL
Ozz
970-484-2577
800-424-2577
516 Highway 287
Fort Collins CO 80525
89
5.0 AOD 0 1575
2117 0.0 $75.00 116 Call MORGAN AUTO PARTS
800-333-3140
719-545-1702
A
AdamDude04
Thanks M! I was considering trying the yard..and the prices I picked out were roughly $60-100 as well.. but who knows the condition or how long that will last. Maybe I'll get three years out of it, or three weeks..if on the shorter end, I might as well just buy new, ya know? But that's a nifty site to use though! I'm going to bookmark that shaznat right now lol make yard searchin much easier!
I emailed a couple places last night about replacing the ujoints, and have to call another place on monday (dang weekend) to get an answer if they can replace the joints for cheaper than the cost of a new one.
yo Adam,
Why not replace the U joint yourself and save the $ and aggravation dealing with that "shop".. they could replace the joints quickly & ezily if they knew what they are doing; which appears Not..
I still can't figure out if it's the front or rear DS joints you need done;
so look in my site under DRIVELINE; -> Universal Joint -> Installation, Removal & Repairs
and read thru a few concise and good links such as;
Installation in a Dana 44 (front drive shaft)
Source: by Keith L (TTB Blows, Bling-Bling) at http://www.supermotors.net/clubs/superford/vehicles/registry/139/13251
Installation, Driveshaft in an 89
Source: by publicjohncue at http://www.supermotors.net/vehicles/registry/15446/52035
Parts Break-Out Diagram, Double Cardan, rear driveshaft in an 88
Source: by Dustin S (Dustball, Mellow Yellow, Mr. Laser Boy) at http://ylobronc.users.superford.org/documents/CVdiagram.jpg
Universal Joint TSB 97-20-15 for 90-96
Source: by Ford via miesk5 at http://home.comcast.net/~miesk5/technical_service_bulletins.htm#Door,%20Side,%20Wind%20Noise%20TSB%2099-6-5%20by%20Ford%20for%2094-96
wileec
Erie CO
Adam, Check with http://www.automotivepartsunlimited.com/ for a new one. He builds 1350 shafts for about 300 and the stock ones are real good price. the big shaft is great for me and was balanced with very little weight. After you get done buying 4 ujoints and getting the shaft balanced you might as well get a new one.
Here is the contact infomation-
"Automotive Parts Unlimited, LLC
Fullsize bronco's source for gears, drive shafts, axles, and bearings. Call and ask for Eric for discounted FSB prices. 1-800-270-5224"
As you can see he is a vendor on a different site but he will sell to anyone :-& #036; His shipping was fast had the shaft in 3 or 4 days.
A
AdamDude04
I think I may attempt to replace the u-joints myself (with my buddy). Though if I do that, and I fail, I'll need to have a shop do it for me. Ugh.
Toss up on what to do..
Here's the email I got from the local driveshaft shop -
Hello,
I have a double cardan rear driveshaft off my 89 Bronco that needs new u-joints. A few other places I've called won't even touch the thing, and others want to charge a huge price when I could just buy a new one for cheaper..
So my question is, how much would you charge to replace the u-joints?
I work odd hours, and email is for the most part the best way to reach me, but my phone number is:
Thank you,
Reply Forward
Colorado Drive Shaft
(4 hours ago)
$75.00 to replace the two u-joints in the cv. If the precision pin is bad between the u-joints then it will be closer to $220.00. We have to cut off parts, replace them and balance it then.
Those photos of the process help Miesk. Though I'm going to try getting a quote from the guy wileec posted about.
wileec
Erie CO
I would guess you are going to be into the old shaft close to 130-150 if you do the joints yourself. Should be easy to do, I replaces my rear joint many a time on the side of the road before getting the 1350s.
A
AdamDude04
Well I got a price quote from the driveshaft compnay in lakewood, NJ.
They told me it's about 7-10 days before the product would ship out, so I'm looking at roughly 2 weeks max before I get my fix. And discount price is at $200 plus shipping. I can't wait that long. Plus for at most, an extra $20 I could just have the local driveshaft spot do everything and get it back same day.
I really want to attempt this on my own..but I hate doing u-joints. A lot :angry:
Ford644
