wheels
badbronc87
im getting some bfgoodrich muds 33x12.5x15's. will they mount on my stock rims? I think they will, and i really cant afford new rims, and i dont really wanna go to a 33x10.5 if at all possible...thanks
I hate to tell you this, but if you mount the 33 x 12.5's on stock rims you have voided the tire manufacturers warranty. All manufacturers spec a minimum of 8.5 in. rim width. Stock rims are a maximum 7.5 in. A 31 x 10.5 will fit stock rims.
You will have people say they have them mounted on stock rims and it is physically possible to stuff them on stock rims. HOWEVER, you run the risk of popping a bead which means instant flat. If you do that and it results in an accident, perhaps a serious one which may result in someones death, you will be on your own. The manufacturer is not responsible for using tires outside of their specifications.
My suggestion to you, is: Since you are going to spend in excess of $500.00 on nice looking tires, wait untill you have the proper wheels to mount them on. Your truck may also need atleast a 3" lift to prevent them from getting ruined by the edges of the wheel wells cutting the tread when the suspension flexs. Even with the lift, there will most likely be slight rubbing in the front on the radius arms in hard over turns, solution: "Don't do that".
badbronc87
thanks for the advice, yeah im putting on a 3 inch body lift before i get the tires, ah its disappointing tho, but just a little set back, maybe ill go with the 33x10.5's for now, unless i can find some of the cheapest aftermarket wheels(least expensive) mine are 15x7.5's, you dont think i could get by with them for a little while?(on the 12.5's)
22632[/snapback]
If I were the owner of a tire shop, I wouldn't do it for you, because it would make me financially responsible. However, it's your truck :) /emoticons/[email protected] 2x" width="20" height="20" /> .
Wihill
