What is this metal switch under my dash? I have no idea what it is?
A couple ideas.
As Notaveg suggested, lights would be one good guess, or possibly a winch.
Are there any mounting holes or signs of missing brackets on the roof or front end of the frame or one of the bumpers? That might give you a clue.
It could be also have been used/be being used as part of an alternative/work-around or replacement circuit to get something original working that wasn't.
If you can trace the wiring, the wire gauge AND/OR strength and presence of a fuse or circuit breaker or relay, or fusible link (if there IS one) might give an idea of how much current it was intended to control.
Very thick wiring and a high amp rating on the switch is likelier for something that's a big draw running without using a relay.
A common possibility that would
not need heavy wiring is the fuel pump or ignition circuit.
Either a manual switch to bypass a problem in the original wiring
or that someone added as a no-start switch to help make it harder to steal the truck.
The switch placement says that they weren't
necessarily trying to HIDE the location-just not make it instantly obvious, but it sure looks to be in a odd place, one that could easily get accidentally tripped.
If the wiring is still live, you can always try both positions and see if anything stops working........
