What are these for
Does anybody have any idea what these are for besides gauging chunks of meat out of my back and head?
Elmo
Forsyth Georgia
I have always figured they were used to locate the frame in a jig during assembly. Altho the pin being that large seems a bit excessive for that purpose. I usually cut them off after i hit them two or three times with my head to check for regidity
hammer down bronco
pa.
also why are there just random holes in the frame? it seems like theres no plus to them accept to accelerate rusting
yo!
I think they're for the production line too. Altho very substantial, they installtion of engines, etd. were more "brutal" than today's Robot lines.
Ford also refers to them as Studs when doing an "Underbody Misalignment Check"
this is for a 96 F 150 Regular Cab Short Bed (4x4)
MEASURING POINTS Item Description
1 15mm (0.59-Inch) Hole
2 Bolt
3 15mm (0.59-Inch) Hole
4 Bolt
5 Stud
6 Rivet
7 Stud
8 Rivet
9 Stud
10 8mm (0.31-Inch) Hole
11 12mm (0.47-Inch) Hole
12 12mm (0.47-Inch) Hole
13 12mm (0.47-Inch) Hole
14 12mm (0.47-Inch) Hole
15 Rivet
16 12mm (0.47-Inch) Hole
17 11mm (0.43-Inch) Hole
18 Rivet
19 Stud
20 Rivet
The dimensions of the underbody must be restored in repairing major body damage to provide correct front and rear wheel geometry. Refer to the Underbody Dimensions diagram for the underbody dimensions. All the dimensions are detailed to the centerline of existing holes in the underbody assembly. Once the frame and suspension members are aligned, other operations in this section can be performed.
NOTE: All dimensions are true point-to-point in inches. Measuring can be performed using the Rotunda Complete Laser Measuring System 190-01025 or equivalent.
Door openings are checked in the same manner as the body. Horizontal, vertical, and diagonal checking points are established on all four sides of the door opening that is being measured.
