weird start?? oil pressure??
BubbaBroncoII
I have a 1989 Ford Bronco II 177ci v6 (2.9), I take extreme care of my truck but one thing that is starting to annoy me is how it starts. it has almost 40,000 miles......i know.......LOW......but it wont start sometimes untill the oil pressure goes into normal....in the morning its fine...but if run around for a while, it gets hot and wont start untill that pressure gauge goes into normal.....????? I bought this truck about 5 months ago for $850 and turned to well over $5,000 in value since and now i just need to fix this problem. Could it be the spark plugs and wires and distributor that need to be changed or is it something more...i dont care i am only putting high quality parts into this baby for my off roading needs PLZ help....Thanks, >
89Bronco58
Jersey
so basically, you turn the key and the motor just cranks and cranks until the oil pressure builds up a little bit, and then it starts?
andre
gatineau hill quebec
put you're key on about 3 time before u starts "when hot" to build up pressure c if it start. yes
losing fuel pressure .
other thing check.. put timing ligth on one plug check if spark there when hot
may b ingniter starting to go
hope this help u to pin point prom
digs
