weird blinker issues
coolio2281
Union City, OH 45390
ive got a 93 Bronco with the 5.8, well my problem is really weird...its about my turn signals...first symptom was my left blinker would work but the light wouldnt blink, then next my right signal would act like a mind of its own, sometimes work, sometimes wouldnt, then that symptom jumped the road to my left signal, and now iam at a point where neither of them work, nor light up...and yeah getting pulled over for no turn signal isnt something thats on my to-do list....any idea's of what the hecks going on here?! or is my truck just mad at me cause she hasnt been washed in a month? haha
yo
Turn Signal & Flasher Trouble Shooting, General Source: by procarcare.com
Appears to be the Multifunction Switch (MFS), Check it out with this Testing & Wiring Diagram in 92-96 Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
The MFS has 2 connectors; call em Top & Bottom, disconnect Top Connector and do da test.
Multifunction Switch (MFS) Replacement in a 96 Source: by boss (bossind, Steve) at 4x4 Preservation
Multifunction Switch (MFS) Replacement (SW5591- F8TZ13K359AB) in a 93 Source: by Kevin L at kevin-long.tripod.com via web.archive
If MFS is bad, get one from any 92-96 Bronco or Ford Truck bec as Steve wrote; They are electrically & functionally identical. Only the shape & finish of the stalk is different
C
coolio2281
so i got the switch and lever for the turn signal out i dont really know what to look for but all connectors are there,,,what do you suggest i do, buy a new switch? lever? or both? their very expensive
95 buckin bronco
tennessee
yeah this is all for replacing...and no where on the list of symptoms did i see nuthing working at all
man he is tryin to help u out no reason to snap at him u can test all ur switches to see if they operate properly get a tester with noise control(beaps to let u know that it has power comin through) hook the black up to ground and touch red to every power point then turn the switch on one point a a time.like bright lights.first u have to fint the point for bright lights then touch black to ground and red to that point hit the switch if it beaps then that point is good.do this to every point.when u find one that doesnt beap when its suppose to then u have found the problem if the switch works correctly then start lookin at the wires.
I woulda copied & pasted the Exact Troubleshooting procedure here in my reply I posted;
BUT the doc is a pdf and I don't have the proper software to convert it to a file & copy the "TO TEST" info and paste it here.
So here is the doc..click on it to enlarge;
95 bucking bronco took his time & effort to log-in and help you...test it w/a cheap self-powered tester, or as the doc describes; an Ohmeter which is for general automotive testing purposes, a multimeter set on OHMs
BTW, this TEST does not show symptoms; the first LINK I posted shows common problems and common solutions, so that we know for example, a fuse is ok...there was no corrosion in socket, ad nauseum....
And since your description was lacking...."...first symptom was my left blinker would work but the light wouldnt blink..." the blinker that works..is that the instrument panel's Blinker or the tail light?
and the last two Links I shows how to remove the MFS for your testing purposes.
GL
C
coolio2281
my apollogies not here to bash anyone but iam sure you have all been in my position, one problem, after another, after another, one doller amounting to 2 dollars amounting to thousands...i cannot drive a vehicle without turn signals, i took apart the switch i dont really see anything wrong with it what so ever i cleaned up all the brass fittings and connections and still all that works is the hazards/wipers/brights...pretty much everything except the turn signals..iam checking out your link as we speak MIESK5......thanks for all of your help
2percent
Painesville Ohio
Yeh Miesk pretty much covered it all and it is legal to drive without signal light just use your arm signals might be little cold but it is legal I believe in all 50 states.
AdamDude04
Until you fix the issue..
remember the hand turn signals (often what bikers do)?
Arm straight out the window means you make a left hand turn. Arm out the window, but point up at the sky means you're making a right turn. Sucks but better than a ticket...
C
coolio2281
yee...hey i do have another question tho, i took the switch apart...as i said i cannot tell what is wrong with it, but is there anywhere i can find a diagram of how it is built/peiced together, i know to peice it together, but for some reason i have 2 springs...one goes under the emergency flasher button, but have no idea where the other one goes..maybe this is why it is malfunctioning
yo!
NP!
Look @ this; its for an 01 Explorer, but as Steve wrote; should be electrically & functionally identical to our years..
http://sites.google.com/site/mfs01explorer/
See the springs? one should be for da Lever; clean contacts as described and try; or get one cheap @ a yard with a return policy that doesn't cost you $.
50joe
Trenton NJ
If it's any consolation, that same multi function switch was used on multiple vehicles for several years by Ford, and I have changed countless amounts of them. (including my own). The Ford ones are rather pricey, but an aftermarket company called Wells sells them too now. If you can find a parts supplier by you that sells it, you may want to check the price on it. The junkyard ones tend to not be the greatest due to lack of use and moisture issues from missing windows/doors or whatever. But, if it works in a pinch, go for it.
C
coolio2281
sweet ya..i ended up peicein it back together and now blinkers work, but my hazards dont haha...guess its just gonna have to do till i get outa school...thanks agian for all the info guys
germanflames
montana
have you checked on ebay I've seen them brand new any where from $30.00 to $70.00, LMC sells theirs for $59.95 so its comparable to ebay.
C
coolio2281
yeah ive checked em all out..but iam sure u can understand, a year ago i could spend 60 bucks and not blink an eye, but not now...its just gonna have to do untill i start pullin in some more cash, insurance/gas/food/rent is a little more important rite now, but yah thanks anyways bud...
honesthat
