waterpump bolt
murph
North Carolina
I was swapping the waterpump on my 91 w/351w. The bolt that is directly under the thermostat housing seems to be crossthreaded. Does that bolt go into the block? It looks like there is a bracket holding the pump to the engine. Need help quick.
wrachet
Kansas City Area
When I needed a new bolt or two..it was a trip to the hardware store for me..sometimes the autoparts store would have what I was looking for but 95% of the time the hardware store came through.
Colleen
Ziggy
Riverside, Ca
Before you reinstall your new bolts, retap the hole and clean it out real good to remove any crud or chips. I put a little RTV on the threads of my thermostat housing bolts to help prevent stuck bolts and I have replaced them with stainless steel bolts as well.
Ford644
