JRose_89
Now I have water in the engine oil!!! I know where the problem is, however I don
What is "Indian Head Gasket Varnish"?Also honestly I just bolted it down, Did not know it needed to be torqued. If you could do you know the specs?xx said:All intake gaskets are coated & should NOT have additional sealant applied. Xxxx
But I think it's more likely you didn't torque the intake properly, or it's warped or pitted.
