wat to do with my 302 on limited budget
73BroncoFreak
Hey I am 17 and I got a 1973 ford bronco fully restored, but my engine is tired and I'm thinkin of havin it rebuilt cuz Im on a limited budget wat do you guys think Ill show you some pics of my sweet ride soon!!
S_bolt19
Colorado
Depending on how "tired" your engine is and what your limited budget is, are going to determine what you will be able to do. What kind of budget are you looking at. I had my engine rebuilt, bored .030 over, roller rockers, 87 5.0 heads and a few other minor things done for $2200.
If you are on a limited budget and are mechanically inclined, you can rebuild it yourself. There are a few things you might want to farm out to a machine shop, but sweat equity always makes the out of pocket expense lower.
chesapeakecowboy
Limited budget is pretty vague. Cheapest way to go is to rebuild yourself and put back stock. Even this depending how good your parts are can cost 1000-1500. If it still runs pretty good and you can still drive it, you are better off driving it and saving your money and doing it right the first time out. It's like anything else once you start the sky is the limit, but with big power comes bad fuel mileage.....
Mach1460
S_bolt19, I have an 79 351w that I would like to get some more power out of.. I noticed that you used some 87 mustang heads. What kind of increase do you think you got out of that? I have an complete 5.0 out of an 88 mustang gt
mwood44
I got a parts store 302 long block @ $1200 for my 70. The do it my self rebuild would have cost very close to that and had no warrantee. A ring job would have been a few hundred, but a ring job is not a rebuild.
Mike
Palmer, Ak
Man you guys EBAY is your friend you can build a very good motor with brand new parts off there very high quality for around $500 racers outlet and maddog racing are a couple very good ones name brand stuff cheap . :D /emoticons/[email protected] 2x" width="20" height="20" />
The first thing you wanna do is take a compression test, if it is good and consistant, never mind the bottom end rebuild, focus on a cam, an intake/carb and exhaust. (Not necessarily in that order)
Merry Christmas
Similar threads
T
Replies
Views
1K
Top stories on BroncoZone.com
T
T
Replies
Views
997
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
79' Buckin Bronco
