Warn Manual Hub Locks
avp12304
i recently put a set of warn premium hub locks on my truck, but when i try to turn them from free to lock, or lock to free, you'v gotta turn on it unusually hard, if i took off the cap and lubed it up a bit would this fix the problem?
stinger
East TN
i have the same hubs on mine and they are hard to turn and lubing didnt help mine they just work tight.
A
avp12304
I just asked the same question on a different website and they said lubeing it wouldnt help, its just how warn hubs are, after using them over time they loosen up supposedly
Broncoholics
Broncoholics
Washington State
Mine were easy to turn new and got harder to turn with age.
I cleaned them out with brake clean and worked them back and forth and it helped. From what I see grease doesn't help it move which seems odd. I guess it only lets dirt stick and cause this problem.
I have a set of Superwinch hubs and they turn almost too easy and they are a simple design with no snap rings and things to fail like the Warns.
dicain
just get a hub tool they re 6+ bucks. they help when you can find it in your truck. plus my buddy has the super winch hubs on his bl#*%r and they unlocked, and stripped out.
