Vintage Air installation Gen 4
1969bronco32
Estero,FL
Evening.. its hot here in SW Florida..thinking of installing Vintage air system..any issues with install? difficult? how much modification was needed...302/3 on the Tre/ no power steering...thanks John
I had installed one, I mounted mine between the front seats instead of under the dash though. I had a console under the dash I didn't want to take out.
The vents pointed pretty much up. I thought it worked pretty well. pushed cold air towards the back and front.
It worked but that was the old R12 systems. Not sure if the newer 134 systems are as efficient.
The EB's of course have little insulation so if you are looking for a cabin temp of 65 degrees it probably won't happen. It is certainly livable though.
Elmomo
