VIN verification
Auggie
Saint Augustine, FL
I am trying to verify that I have the glove box for the Bronco that I bought.  I just found the VIN on the frame ( passenger side, top) and it does not appear to match the glove box VIN code.  Is there any way to verify the VIN's.  I have not found anything online...everything asks for the 17 digit VIN.  The decoder in the back of the Bronco Graveyard does not have the numbers/Letters seen on my glove box nor the frame...any ideas?  Pictures included.VIN77Bronco.jpgVINglovebox77Bronco.jpg
fyreduck1921
Alton, IL
Vin
U15 = Bronco wagon
G = 302 V8
L = Michigan assembly plant
002292 = serial number
Color - T = Candy apple Red
Trans - C = 3 speed manual
Axle - B8J = B8 is rear axle code = 3.50 ratio limited slip. J is front axle code = Dana 30 Limited slip
DSO - 26 = New Orleans
Auggie
Auggie
Saint Augustine, FL
The numbers on the title are the same as on the glove box.  My question is the numbers on the frame looked to have been "over stamped".  Are you able to make out the numbers on the frame picture?
OH!   And thank you Fyreduck1921........did not have all of that info.  Of course I assumed "T" stood for Tan! :glare:
fyreduck1921
Alton, IL
Auggie,
I got a better look at the numbers on my desktop. This is what I see
Glove box tag: U15GL02292
Frame: U15GL01228* with the last character being unreadable. From what I read,  that only changes the serial number and not by much, so it would only affect the build date by a few weeks.
Steve
Auggie
Auggie
Saint Augustine, FL
Hey Steve,
Thanks.....that is what I was seeing also.  The only issue is that every piece of documented paperwork I have is based on the glove box number...title, registration, etc......  How do you decipher the dates?
Bruce
fyreduck1921
Alton, IL
Bruce,
Sorry for just getting back to you. Depending on which VIN decoder you use will determine how close they get on your build date. Some only give you the year. Even so, if we are given that VINs 00001-12000 were in a given year and we have a truck who's VIN ends with 06000, it would be safe to assume that truck was made in the middle of that year.
Auggie
Auggie
Saint Augustine, FL
Thanks!  You are right about the decoders.....but I have been able to determine I do actually have a 77.  Thanks again.
