1994 5.8L Bronco W/Automatic Hubs
Well I replaced the rear axle seals and pinion seal about 2 weeks ago... I was driving home and noticed a slight vibration & "grinding" noise coming from the front right wheel, but only when i turn left... it is not a constant when turning left, it is dependant on the speed.
I pulled into the drive way at a "snail's pace" and noticed that it is only at certain points when turning... almost like it is one short vibraion/grinding per every full rotation...
I have rebuilt the front left hub with new bearings and seals, but didnt do the right side... curious to know if I can just replace the bearings and seals and the vibration go away?
Just trying to get an idea what I'm possibly looking at before i jumped into it...
Thanks in advance.
Thanks in advance.
