Ray_Bronco
i have 96 bronco 5.8L 351 windsor.. i am redoing my vacuum lines w/ 4mm plastic lines. I noticed there is a opening in the plenum that would allow me to run my vacuum lines from the erg valve and smog container (i think that is what it is) directly to the black mechanism near the coil.. I would not have to go around the back of the plenum.
would anyone know if i run these vacuum lines (inside a split loom) thru the opening in the plenum, would they risk melting or catching fire or any other issues..
thank you ray
thank you ray
