Under Hood
walkdawg
Jacksonville North Carolina
I guess Ill put a btter of mine but it compares nothing to what you all have under your hoods I will do some fixing up down the road. I am thinking about getting a 351 to put into mine.
'Cuda??? No way, dude, it's from a Ford Falcon XY from Australia.
How can you tell the HP just by looking at an engine???
Good job, Freak!
Bronco_In_Ny
Bronco_In_Ny
Back In bradenton Fl
you really can't just look at a engine and tell its HP unless its stock with no Mods then you can find the hp online if you don't know it already B)
freak
Indiana
I had mine ran on a engine dyno before I put it in.The best horsepower was 422 @ 5500 rpm and the torque was 460lb ft @ 4000 rpm.From 1600 rpm to 5300 rpm the torque is in the 400 lb ft range.This was all with a 750cfm carb,I tried an 850 cfm carb,while it had more peak horsepower at 5500 rpm(439HP)the torque was not there.The 850 was just to big.
sweepersrgr8
"GET ER DONE"
Charleston,SC
See, I was right... in EXCESS of 400HP. This was just a guess, because I had a '77 F100 with a 400 with just a performer intake, 600 cfm holly, comps 270 off road cam, and mild porting that produced 396 rear wheel HP on the dyno. FREAKS looks much meaner.
dicain
freak's bronco is what every chevy owner fears! :eek: /emoticons/ohmy@2x.png 2x" width="20" height="20" />
hawk2100n
Wants Overdrive
here is my home made intake and air box. i ditched the old pre heater and air box and made up an airbox out of galvanized that sucks air from the retangular hole next to the radiatior.
Wliebhard
Albuquerque, NM
Let's try this again...
Here's my project money pit. A 12 valve Cummins with Intercooler, Auto tranny, 241 HD t-case, and computer out of a '95 1 ton Ram. If you have any questions, I probably have answers. I will be on the road Tuesday (next week :angry: )
RAAAAA MORE POWER!!!!!
mansquirt86
Redwood City, Cali
[SIZE=14pt]Wliebhard [/SIZE] OMG!! how in the **** did you get that cummins in there man? that is seriously the craziest sh*t i have ever seen. I LOVE IT. If your ANYWHERE in cali, i will drive there just to see this thing.
Wliebhard
Albuquerque, NM
mansquirt86- It went in with a 3" body lift, help from Ford-Cummins, and ALOT of 'massaging' from my sawz-all. I had to dump the A/C, but the top come off, right? I also installed the brake booster and M/C from a '97 f-350. I had coil spring specialties fab custom springs for me.
sweepersrgr8
"GET ER DONE"
Charleston,SC
4XFAN, here's your answer.
Wliebhard, excellent job man!
figjeti
