Hi all, I'm new to this forum and this is the first time posting. Just recently bought a 94 Bronco with the 302 and 5 speed manual transmission. It has about 120k miles on it, both the original engine and transmission.
When I shift the truck into 5th gear, at about 55 mph, there is a low grumble noise. It is most noticable between 55 - 70 mph. It does not seem to affect acceleration too much. Has anyone experienced this issue? If so, what have you done about it? I've talked to some different people, most people say that 5th gears sounds like it is going and I should change my transmission fluid. Doesn't seem like a problem and easy enough to do, but then a few people told me that it is actually bad to change/add the transmission fluid on a vehicle with over 100k if it has never been done. Being that I just bought it, I'm not sure if it has been done.
Any advice will be appreciated. Also, sorry if there has been a topic similar to this posted, I was looking but couldn't find it. Again, still getting used to this forum.
Thanks
Thanks
