i hear a fairly loud whining noise while the engine is running and feel a hard shift between 1st & 2nd gear. this is a 76 with a C4 i just purchased. wondered if there is a problem coming up? i checked the fluid it was red and the right level. at this point im just assuming a possible trans problem any thoughts? i do have power steering so i will check the fluid cause i read on another post that can cause some whining noises. but this seems to loud for that.
