Possible Component | Reference/Action |
220 — ELECTRICAL ROUTINE | |
Powertrain Control System | |
- Electrical inputs/outputs, vehicle wiring harnesses, powertrain control module, throttle position sensor, vehicle speed sensor, shift solenoid 1, shift solenoid 2
- Run On-Board Diagnostics. Refer to Powertrain Control/Emissions Diagnosis Manual for diagnosis. Perform Service Manual Pinpoint Test A using Rotunda Transmission Tester 007-00085 and Cable and Overlay 007-00107 or equivalents as outlined in this section. Service as required. Clear codes, road test and rerun On-Board Diagnostics.
320 — HYDRAULIC/MECHANICAL ROUTINE | |
Shift Linkage (Internal/External) or Cable | |
- Damage, misadjusted
- Transmission Range (TR) sensor damaged, misadjusted
- Inspect for damage. Service as required. Verify linkage adjustment as outlined. After servicing linkage, verify that the transmission range (TR) sensor is properly adjusted. Refer to In-Vehicle Service in this section.
Main Controls | |
- Bolts not tightened to specification
- Retighten bolts to specification.
- Gaskets damaged, misaligned
- Inspect for damage and replace.
- Shift solenoid 2 malfunction
- Refer to Electrical Routine No. 220.
- D2 valve, 1-2 shift valve, 1-2 manual transition valve, intermediate clutch accumulator regulator valves, springs — stuck, damaged, missing or misassembled
- Air bleed for shift solenoid 2 circuit damaged or missing
- Inspect for damage. Replace case.
- Wrong parts used in rebuild
- Verify that proper parts were used.
Intermediate Clutch Assembly | |
- Air check clutch assembly as outlined in this section.
- Friction elements worn, missing, damaged, misassembled
- Feedbolt torque incorrect, leaks, missing
- Inspect and retighten bolts as required.
- Cylinder assembly outer diameter/case bore damaged, leaking
Intermediate One-Way Clutch Assembly | |
- Cage/sprags damaged, improperly assembled on inner race
- Improper components used in rebuild
- Verify that proper components are used.
