yo R,
AOD, C6 & E4OD Identification
E4OD, AOD & C6 Pan Identification & Driver Side pics;
Source: by Kenneth at
http://www.technicalvideos.com/identify_my_transmission.phtml
E4OD have 20 pan bolts; P-R-N-D-2-1 shifter pattern - shift indicator pic by Chris A
http://www.supermotors.net/clubs/superford/registry/media/117390
AOD have 14 pan bolts, see diagram & pic; P-R-N-(D)-D-1 shifter pattern, note, OD is actually a (D) - shift indicator pic by trigger @
http://img.photobucket.com/albums/v663/RampageFSJ/a4-1.jpg
C6 have 17 pan bolts, see diagram & pic; P-R-N-D-2-1, shifter pattern - shift indicator pic by miesk5
http://www.broncolinks.com/gallery_images/C6ShiftIndicatorpic.JPG
Some common E4OD Issues
My 96 OWNERS MANUAL SHOWS 16 quarts for fluid change
http://www.hillerford.com/resource_library/owner_manuals_pdf/1996_owner_manuals_ford/96bronco.pdf
see Page 344
and from 1996 All F-Series and Bronco with E4OD Automatic Transmission Workshop Manual
Motorcraft Mercon® Multi-Purpose Automatic Transmission Fluid Ford XT-2-QDX or equivalent meeting Ford Specification ESP-M2C166-H
Fluid Capacity
E4OD (4x4) Using new style elastomeric transmission fluid pan gasket 16.4 Quarts
E4OD (4x4) Using old style cork transmission fluid pan gasket 16.2 Quarts
Approximate
capacity includes transmission fluid cooler and transmission fluid cooler tubes. Fluid level indicator (7A020) should be used to determine actual fluid requirement and fluid specifications. Check level at operating temperature. DO NOT OVERFILL. An additional 0.3L (0.3 quart) is required if vehicle has an auxiliary transmission fluid cooler.
Filter, Internal, Grommet Warning; "...When ever you go to change your trans filter, Always make sure to pull out the little round rubber do hicky thingamabob. Lets call it a gromit or a seal? Theres this part of the trans filter that is inserted into the trans (a round tube that goes up into this hole ); Now the tube has a gasket of sorts that wraps around the tube ( kinda like a wide O-ring )It form a seal between the tube and the hole it goes in. Well what ended up killing my trans was that fact that the last guy that changed the trans filter didnt notice that this o-ring thing (gromit Or what ever) did'nt come out with the filter it stayed in the hole! He left it in there; & installed the new filter witch had its preinstalled gromit already; So what he did, is he (unknowingly) stacked two gromits on top of each other, Witch did not let the filters tube fit as it should. It was starving itself for fluid!! It was sucking air as well as tranny fluid! (in other words not working right) ..."
Source: by BlancoBronco (Cam C , Project BLANCO
Filter Magnet; E4OD Kills Engine in Gear; "...works as a filter retainer; w/Ford PN and size; basically this is a magnet Ford uses to keep the filter in-place tightly into the pump; Ford pn F3RZ-7E290-AC..."
Source: by spxfiltran.com via web.archive
