Yo gjonesjr1,
A belated Welcome!
Sorry for the delay.
Are you referring to the Mazda M5OD 5 speed manual transmission?
If so, Motorcraft® MERCON® V is a premium-quality automatic transmission fluid recommended by Ford Motor Company
"The risk of using cheap generic ATF isn't worth the meager savings over genuine MotorCraft Mercon. Shop ebay, Amazon, RockAuto, O'Reilly, PartsPlus, your local Ford dealer, etc. for the best prices" by Steve
If not, look at the label on the B pillar next to the driver's side door. There is a code for the transmission, along with other codes.
Post code here.
Here are the 1989 Ford Bronco EVTM, Emissions (yellowish/red book cover) & Pre-Delivery Manuals, Partial via mrnewland1 in Google Drive @
Haynes Red Manual for 80-95 Bronco & F Series @
Haynes guide 80-96 bko f series.pdf found by BroncMom
989 Ford Bronco Dealer Brochure
See1989 Bronco
Lubricant Specifications by Ford via Gary
