Transfer case slips out of 4x4
GDHale
I have a 1993 bronco with electric shift. Shifts into 4x4 then while driving it slips out of 4x4 and into neutral. Press button and goes back into 4x4. To test the electronics, I put it in 4x4 and unplugged the shift motor then drove it. It slipped out of 4x4 into neutral. Plugged the shift motor back in and put it in 2x4 and drove home. Years ago, it used to slip into neutral when driving in 2x4
Most likely it is a busted shift fork inside the transfercase I believe.
With the motor off I can't imagine what else could do that.
Busted shift forks are pretty common.
Yo GD,
WELCOME!
Recall, BW 1356 Touch-Drive Electric Shift Transfer Case in 93 Bronco & F-Series 4x4 Vehicles Safety Recall 93S65; THE TRANSFER CASES HAVE BEEN BUILT WITH THE WRONG ELECTRIC SHIFT MOTOR. THE TRANSFER CASES CAN SLIP OUT OF THE 4 X 4 HIGH GEAR POSITION DURING COASTING IN FORWARD GEARS OR WITH POWER APPLIED IN REVERSE GEAR. IF THIS OCCURS, THE VEHICLE CAN ROLL FREELY AS IF IN NEUTRAL POSITION REGARDLESS OF THE TRANSMISSION GEAR SELECTOR POSITION. THIS CANRESULT IN LOSS OF VEHICLE CONTROL AND AN ACCIDENT. REPLACE DEFECTIVE TRANSFER CASES WITH THE CORRECT VERSION.
See Recall info below.
1356 Electric Shift Troubleshooting & Repair - BEST PROCESS! @ http://web.archive.org/web/20100923...rford.org/documents/electric1356/elec1356.htm
Source: by Dustin S (Dustball, Mellow Yellow, Mr. Laser Boy)
Find out if speed control, if equipped, recall work is completed.
If you still have concerns about Recalls, please contact the Customer Relationship Center:
US: 800-392-3673 | CA: 800-565-3673
Note: 3673 spells "FORD" on phone keys
For the hearing- or speech-impaired: Please contact the Telecommunication Relay Service by dialing 711.
... have VIN ready.
Here is the 1993 Bronco Dealer Brochure in Google Drive @ 93Bronco.pdf
1993 Bronco Dealer Training Video via silver70 @
1993 Bronco, Venezuela Commercial @
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf via BroncMom
G
GDHale
Thanks for the info. I have been dealing with this for years and no one has ever had any idea. I will post what the fix was when I have it all worked out.
wyo58
Laramie WY
Okay to add to this thread, I have 1992 Bronco, manual hubs, and shift on the fly. 2wd has never been an issue as well as 4wd low. However it does slip out of 4wd high, and it is only on coast going forward. The 4x4 light stays on but it disengages like no power to the wheels. You stop and put it in park and it chatters on the parking pawl, so the trans is spinning. Transfer case has been replaced (reman), as well as the shift motor. The connector has been cleaned from all the old ford electric grease and all connectors look good. I have put the unit in 4wd high and pulled the shift motor and it is dead on the mark. I have also tested it without the manual hubs and not been able to get it to slip out ( maybe not enough time ). It has never done it in 2wd or 4wd low. So I'm at a loss, electrically everything seems to be working perfectly. Now I'm wondering about the coil on the front drive line, if it is some how doing this. Any help would be appreciated.
Not sure what you mean by coil on the front axle. Can you explain more?
It really has to be your transfer case. Put it in 4 hi. Take the motor off and go for a drive and that will eliminate any electrical problem chances. Leaving only mechanical.
wyo58
Laramie WY
It is an electric clutch that spins up the front drive line to match the rear speed, hence shift on the fly. The original transfer case did exactly the same thing as the reman is doing. So I agree in eliminating the electrics from the equation to figure it all out.
I would have to say I have never seen one. That is interesting.
bigd1948
